XFI cams rated with 1.6 rockers
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I have heard it mentioned before that the lift specs on the xfi cams are given using 1.6 rockers already. Is this true or would 1.6 rockers increase the lift more?
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: XFI cams rated with 1.6 rockers
The specs you see are with 1.6 RRs. So to increase the valve lift to more than what you see advertised you'd need to go with 1.7s, like I did.
Jake
Jake
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That's really not a good idea if you intend to twist it past about 6000 rpm. For a higher rpm combo with durability, stick to 1.6:1 or 1.5:1 with the XFI lobes.
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
I got the 280 xfi just for that reson so I could put on 1.5 to decrease my lift some till I get my 400 crank to make my 350 a 383 then Ill go with the 1.6
Hotrodboba400
12-10-2019 07:07 PM
New2Chevy
09-28-2015 12:35 AM
