removing egr totally?
Car: 86 Trans am
Engine: workin on a 383 for it!
I was thinking of doing this just to free up space and reduce annoyance every time i am trying to work on cylinder heads and such, I wanted to know if I do this what I might be infor weather it be good or bad?
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: removing egr totally?
One thing you may be in for is problems getting through emissions, that is, if you have to get the car sniffed. If you don't have to have it sniffed and only have a visual inspection, that could be a problem too. Depends on how close they check.
1 Post
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
i heard somewhere that PA just picked up cali's emissions laws so you would definitely be in trouble if that's the case.
Car: 1989 Camaro RS
Engine: 305 TBI
Just keep the egr for when you have to get it inspected. You're check engine light will be on without it though.
1 Post
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
I live in Alberta and am deleting my smog and egr in a few weeks. A bud of mine removed his egr and saw no difference whatsoever in gas mileage.
Plus the egr temp sensor is now discountinued and the valve isn't too cheap either. So if you do not need it and your swapping your intake (like me), may as well buy a block off kit and be done with it. And if your home gets emission laws then you can always throw it back in..
Just my 2 cents
Just my 2 cents
Car: 86 Trans am
Just my 2 cents
Just my 2 cents
Car: 1985 Z
Engine: 89 305 TPI
Transmission: 700-R4
Axle/Gears: OSD 10 bolt/ 3.42
are you talking about all this stuff and the hoses and pipes that goes with it?
Because if so i was wondering the same thing, and how hard would it be to do?
1 Post
Those are all part of the a.i.r injection. They pump fresh air into your car when it is cold. You can remove the smog pump (below the ac pump), the diverter valve (the big thing with ears), all those hoses and remove the air tubes on your manifolds and plug them with a 1/4" npt plug I believe, and remove the hose from the cat as well.
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Be sure to keep in mind that an exhaust shop wont touch it if they don't see the air line going into the cat(s). Unless they're cool with it.
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
My exhaust guy tacked that on to my cat to make it look functional. I also want to know what would happen if I got rid of my EGR, I'm considering putting Vortec heads, and an intake. It does still have to be e-tested, aswell.
1 Post
Just run egr. I'm ridding mine, because the components are all 22 years old, and when it dies I dont want to have to be faced with a decision then. So i'm doing it now.
If you install the headers yourself and bring the car in to get the cat cut out and a 3" ypipe and a cutout installed, they will have no problem with that.
Especially in non-emissions alberta
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
in live in Pa as well and before you go taking anything off make sure you have a person to inspect it for you without all the emissions stuff being there some guys are fine with it not being there some aren't it would really suck to take it out and have to put it back on for inspection.
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
so then am i the only one whose car wont start without the egr valve? I was changing my valve covers and forgot to put it back on when i tried to start it. it wouldn't even start. I was also told by a shop that if i dont have the egr valve plugged in it can really mess up the engine in the long run....but thats just what they told me.
Engine: 355 SBC
spiffies that's what i've heard too that if it's not hooked up right or not removed right you cause more harm than good.
Car: 1985 Z
Engine: 89 305 TPI
I took all my stuff off today, and it runs fine
The extra space is nice
1 Post
Block off plates, an burnt into you chip, turning a.i.r and egr off.
Car: 1985 Z
Engine: 89 305 TPI
Car: 1985 Z
Engine: 89 305 TPI
Car: 86 Trans am
ya that's what I was really going for a lot more space, less to worry about as in reparing egr or even having to mess with it, hey I also took out almost all my air conditioning but the smaller radiator ran by the AC looks like it wants to stay and seems like if I want to get it out im going to have to remove the radiator?
Car: 1989 Camaro RS
Engine: LO3
I have an 89 RS 305 Tbi and replaced the EGR valve to get the stupid check engine light off, and now it feels like it is hesitating at highway speeds. It was running fine before I changed it. Can I just block it off? I can live with the S.E.S light to have it running smooth again.
Car: 1989 Camaro RS
Engine: LO3
I saw your response on EGR and noticed you have the same engine as me. I recently changed it to get the S.E.S. light off and now it's not running smooth at highway speeds. You blocked it off and it's running fine?
gixxer92
09-01-2015 04:32 PM
