89 camaro: resistance going uphill
I have a 1989 camaro RS v6 that i'm getting from a dealer. the guy selling the car to me said the car drives fine on flat land but it wants to putt soon as he gives a load to it by driving it up hill. any possibilities? thanks.
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: 89 camaro: resistance going uphill
Manual or automatic???
Hello safireking88!!
Have you driven it up a hill yet???
It could be having some issues with the valve body in the transmission, torque converter, or even the "TV" cable, etc....!!!
If your getting it from a dealer, it should be fixed before you get it, at their expense!!
Make sure that if you do get it, that there is a warranty on the transmission/drive train!!
I'd walk, and find another, however if the price was right, and you had other plans for the car, the transmission "problem" may be of no concern to you!!
The car is only 500 bucks but i talked to the guy selling it and we both considered that it might just need a tune-up or whatever the case may be. I was planning on using it as a temporary beater cuz my bimmer was having issues and stuff then later on fix it up asthetic wise.
Spend the money!!!
Yes, it could only need a "tune up", but it could be a lot worse!! Just don't go throwing a lot of money into it, if you do, you might as well spend it now, and get something better for your money!!
RedLeader289
05-28-2019 01:47 PM
Zachattack0925
08-12-2015 09:52 PM
