Help - Speed wobble
Old 01-23-2010 | 02:56 AM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Help - Speed wobble
Hey I recently finished getting my Camaro running and doing body work. When I take the car out for a test drive it occasionally develops a bad speed wobble at around 25 to 40 mph. It feels like the source is the front right tire.
The wobble happens more frequently and more violently after the first time.
Here's some info to help diagnose the problem. Today the right front tire was flat. I had the car for a year and it was always full. When I pushed on the tire it felt like there was something inside. It felt like snow or something that has the same feel as snow.
Also the wobble happened before the tire was flat (a few days ago and while towning the car home about a year ago). Could have went flat because of the wobble.
Any help is very apprecitated
Old 01-23-2010 | 04:32 AM
Blown 346's Avatar
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
Re: Help - Speed wobble
You could have ice in the tire. I would pull the tire off and inspect.
Old 01-23-2010 | 12:36 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Thats what i'm thinking I will do.
Does anyone suspect a part of suspension as the problem?
Elephantismo
02-13-2019 01:51 AM
RedLeader289
09-23-2015 07:50 AM
roysatikas
09-22-2015 09:15 PM
FormulasOnly
09-06-2015 11:42 AM
FLAP
Camaros Wanted
09-02-2015 10:22 AM
