Can I reuse my block?
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
I have been thinking today and last night after looking at the other post here about the vavle dropping in the cylinder.
I have a little bit of pitting in the #7 cylinder, nothing real bad, but the more I think about it I think that I might be able to use it for the time being. Doing it this way I'll be able to save up my money while being deployed to afghanistan for the new engine and body work. The pitting feels like it is about 020 deep, but only in a very small area.
Is there a real fine material that I can very lightly use by hand to clean up the ring chatter and discoloration, and possibly get a better idea of the pitting that is there?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Can I reuse my block?
You've got a few choices. You can hone it with a 3 stone hone in a drill. .020" is a LOT though. I doubt it's that bad..? Got a good close up picture on macro showing it?
Otherwise you can bore that one cylinder out, or put in a sleeve.
Or you can use fine sandpaper and try to get rid of the "chatter". But now you're really doing a backwoods repair.
I could but I really don't want to do that.
When you hone you use oil with it right? If so, would I be able to use oil on the sandpaper if I don't have room for the honing tools?
edit: whatever I do it really only has to last me about 3-4 months effectively since I'll be gone and saving up my money for something else.
Car: 1982 Trans-Am
1500-2000? You'll be there for a while... And no, the shop will leave a 400-600 grit finish for your cylinder walls, in order for the rings to seal. That grit value will never remove material anyway, you have to go more coarse.
I hone with ATF, but i've been told to use mineral spirits. You're trying to "rough up" the cylinder to get a cross hatch, you don't want to polish it.
I'm not sure how bad the spot is, so I can't really make a recommendation.
The only reason that they leave it "rough" at 600 is so that the cylinder walls and the rings wear together to make a perfect seal matched to each other.
1 Post
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
You should just bore it .030 over.....it's not that much to do that....then you won't have to worry about pitting. Throw some .030 pistons in there and then you could run it until you get back to build it. You have it apart anyways, might as well just get it done right.
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
1500/2000 is too fine. It won't leave the necessary finish for oil retention on the walls which serves to minimize ring wear. In effect, you'd be polishing the bore walls which is what you don't want to do.
You can then use a bottle brush (fits in a drill and has *****) to break any glaze.
600 GRIT is a good choice.
Jake
Jake
skinny z
10-05-2015 06:23 PM
