valve dropped in #3 cylinder(pic)
Old 01-12-2010, 11:56 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
The motor only has 6-8k on it and @ 30 passes. Its bored .040 and stroked. An intake valve spring broke and the valve dropped into the cylinder wall, is there anything I can do besides having all the cylinders bored to .060?
Old 01-12-2010, 12:04 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
Re: valve dropped in #3 cylinder(pic)
get another block and bore it .040 over, this will allow you to use the same pistons and not have to get new ones.
Old 01-12-2010, 01:26 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Alot of money and time were put into this block, all 4 main oil drain back holes were opened up and polish, lifter valley drainback holes were tapped for threaded plugs, front and rear freeze plugs were tapped, its a 4 bolt main 1 piece rms, block clearanced for stroker, rear main cap ported n polished for oil pump. everything deburred and champerd, bored,decked, torque plate honed, file fit rings. All this done @6k ago. I really dont want to get rid of this block.
Old 01-12-2010, 01:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Well, if going to .060 doesn't fix it, then that can all be done again on another block.
Old 01-12-2010, 01:32 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Is there anyway to go .060 on one cylinder. As far as weight goes would it be hard to get this one rod n piston to match to the other ones?
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Could you put a sleeve in that cylinder ?
Old 01-12-2010, 01:40 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Axle/Gears: Ford 9"
take a finish hone to it and see how bad it is and remove any sharp edges. You may be able to run it after the finish hone. Sure you will have a little blowby there but as long as the rings dont catch you should be good.
Old 01-12-2010, 01:46 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
there smooth, no sharp edges I noticed when running my finger across it.
Old 01-12-2010, 01:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A sleeve is a better idea, and not terribly expensive.
Old 01-12-2010, 01:54 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
How exactly do they sleeve it? Any idea on cost or what to look or ask for?
Old 01-12-2010, 02:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They bore the cylinder completely out, put a sleeve in, then deck the block and bore the sleeve out and hone it to the final size. Some people don't like using them, but there's no real problem with them when they're done properly. I have a cylinder sleeved in the block in my 84. The last I checked, it runs around $50 a hole or so.
Old 01-12-2010, 02:13 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Just called alocal machine shop, 120$ labor and $40 for the sleeve
Old 01-12-2010, 02:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Compare it with the price of doing all that work again on a new block.
Old 01-12-2010, 03:46 PM
fwb35's Avatar
Sleeve the cylinder, I did it in a race block I had and nevr had a problem
Old 01-12-2010, 03:58 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
LS1's are sleeved
Old 01-12-2010, 04:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
All aluminum engines are sleeved.
Old 01-12-2010, 04:14 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Just got off the phone with a few more shops,,, If I have to have it sleeved the entire block has to be torn down freeze plugs and all, hot tanked cleaned, so they have to replace cam bearings, the cheapest Ive found its going to cost 400-500 to have it sleeved with everything else thats needed...... Screw it, its going it the car and maybe down the road Ill get a new block.
Old 01-12-2010, 05:20 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Not the Vega.
I'd go along with the hone idea. Don't use a ball glaze breaker, use a flat stone type. Go over it by hand first to remove the high points, the a quick back & forth to give it a cross hatch. DON'T hone the entire cylinder to remove the marks completely, all you want to do is get rid of the metal that has been displaced out of the wall.
Blow by should be minimal, but probably won't be zero.
I have heard of people going more over on one cylinder than the others. You'd want to make sure the pistons are equal weight, though. You're talking about 0.45 more cubic inch in a 0.060"-over cylinder than a 0.030"-over cylinder.
Old 01-12-2010, 09:53 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
sleeving a stock block isnt a god idea, especially in a perf application, try taking it to 0.060" it it dosnt clean up, its a boat anchor id say
Old 01-12-2010, 10:16 PM
GXR11's Avatar
Car: 91 C1500, 84 Camaro, 87 monteSS
Engine: 4.3L,Gen1 350. 391ci & 383 LS1
Transmission: t-5,man vavle body 700r4, no trans
Axle/Gears: 3:73, 3:42, 4:10
id like to know more on why some people say its not a good idea to sleeve a stock block.(other then potentially dissimilar metals and thermal expansion) a good friend of mine had to sleeve a #8 bore from a air cleaner stud some how making it past the valve. either way, he never had a prob with it. he paid $125 to have it done... (just dropping off the bare block to the machine shop)
if i was in the OP's shoes, id just re sleeve it
Old 01-12-2010, 10:25 PM
TGO - 10 Year Member
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
With that damage up high in the cylinder I suspect it needs to be bored. Down lower it wouldn't be so bad, two stroke engines have huge holes in the cylinders and run a long time at super high rpms. If failure wouldn't really upset you I'd say put a set of rings in it and see what happens.
Old 01-13-2010, 07:46 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Failure? Ill get blowby I wouldnt call that failure..... Im just going to put a bottle of Zmax in it,
Old 01-13-2010, 08:09 AM
fwb35's Avatar
We sleeved a engine we raced for a whole season at over 7,000 rpm, never had a problem, re sleeve it.
Old 01-13-2010, 08:17 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Just like Apeiron said aluminum engines are sleeved and almost all of them are performance apps. I would sleeve it .
Old 01-13-2010, 09:11 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Im not spending 400-500$ to sleeve an engine that has 6k miles on it. since its last time to the machine shop. Just dont have money in the budget for that right now. A very light stone hone in that area should take anyhigh spots out and itll run just fine I think.
Old 01-13-2010, 11:02 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I agree, it's at the top of the stroke where the piston spends the most time and cylinder pressure is highest.
Old 01-13-2010, 12:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Originally Posted by five7kid
Not the Vega.
And from that experience it was discovered that it's easier to put sleeves in than it is to control the metallurgy and multiple layers of platings necessary to run an unsleeved aluminum block.
Old 01-13-2010, 12:50 PM
five7kid's Avatar
Engine: LS1/LQ4
Porsche 928 V8's, aluminum block, no sleeves or liners.
Knock the high spots off of those dents, I'm betting you wouldn't be able to tell that cylinder was "different". Might not be what you want for an all-out high-HP engine, but I haven't heard what this engine is being used for yet.
Old 01-13-2010, 05:33 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Its a sunday driver that will probally go to the track 2 or 3 times a year.
Old 01-13-2010, 06:25 PM
five7kid's Avatar
Engine: LS1/LQ4
Stroked 305?
Old 01-13-2010, 07:17 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
No, its a 385 with cast steel crank and forged rods
Old 01-13-2010, 07:33 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Look..whats done. is done..
if you cant feel anything with your fingernail.
or if it's just a lighty there. i would just take it down by hand. Like five7kid posted
till it feels and looks good. and put it back together. and run it.
it will not. hurt anything.. within 2 more years. it will all be the same.
it spends it's time in that spot for less the a milla sec. and half of that..
your fine.. the worst part is knowing it's there...lol
(by the way ..thats nothing!)
put it back together and have fun..
the big thing is, why are your springs FALLING APART??
WITH 6000 to 8000 miles on them??
Old 01-14-2010, 08:24 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
My springs didnt fail, the previous owners did. It was in a mid-high 10sec street car pushing 500hp N/A with a 150 shot on top of that. Not to mention 20-30 passes at the strip in 2 years since it was built
Old 01-14-2010, 04:28 PM
well what ever it was that got one to snap..
i would just finnish and tweek the cylinder by hand and put it back together.. you will be fine.. with all the time it has on it. it will never show anything wrong from that itty bitty gooff.. it will be fine.
db057
08-22-2015 08:17 PM
crazynights
08-21-2015 06:53 AM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
Quick Reply: valve dropped in #3 cylinder(pic)
