crimped Fuel lines
Car: '89 camaro RS
Engine: 305 TBI
Transmission: 700 R4
crimped Fuel lines
I was wondering if it's possible to crimp your fuel lines when jacking the tranny up fixing a mount. my car used to start fine until i jacked the transmission up. when i was done the car takes much longer to start. i think i bent a fuel line and this has caused my pump to go out. if anyone can help it is greatly appreciated.
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Re: crimped Fuel lines
The lines are thin walled steel tubing to you can very easily crimp them. They are located on the drivers side directly by the transmission tunnel. I am not sure how you would crimp them though because I do not recall any good jacking points near the lines.
If you crimped them you can cut out the section by hand, NO ELECTRIC, and replace with a new section and compression fittings. You could also replace the whole line with 6 an braided stainless steel line. However, option 2 would be more costly.
JamesC
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
If your fuel line got crimped, you won't have a hard to start problem, your car would have about 50 hp. You wouldn't be able to make it up hills, it would hesitate upon throttle, etc.
Car: '89 camaro RS
Engine: 305 TBI
Is there anything else i could have done. the hard start problem started right after i replaced the tranny mount.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
did you let the tranny drop any? Is it possible you cracked the distributor cap?
theshackle
03-05-2017 06:37 PM
ambainb
04-25-2016 09:21 PM
AkDrifted
08-17-2015 07:45 PM
