valve springs
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
valve springs
Can somebody lead me to the correct valve springs for running a ZZ4 camshaft in my L98? Any help would be appreciated.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: valve springs
Factory ZZ4/LT4 springs
Get the lightweight LT4 retainers while you are at it
http://www.jegs.com/i/GM-Performance...oductId=761647
http://paceperformance.com/index.asp...D&ProdID=24732
http://paceperformance.com/index.asp...D&ProdID=22758
Engine: 355
Transmission: 4L60
Re: valve springs
Car: 82 Z28
Transmission: T400
Re: valve springs
You're probably going to need more than just the right springs to work with the .544 exhaust lift 1.6 rockers are going to give you on the exhaust. Like having the guides cut down for more clearance.
Comp cams has an extensive line of valve springs both standard and beehive style. You might want to call and ask for their recommendation.
Engine: 355
Transmission: 4L60
Re: valve springs
