2 ton jack VS 2.5 ton jack
Car: 1992 Camaro RS
Engine: 350 .060 over
Transmission: stock
Axle/Gears: stock for now
Is a 2 ton floor jack sturdy enough to hold our cars up? Or would you guys buy a 2.5 ton?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: 2 ton jack VS 2.5 ton jack
2 ton is sturdy enough.
Most of the time you're not lifting the entire car up off the ground.
Our cars weigh in ~3500lbs.
Car: 1984 Camaro Z28 T-tops
![i agree](https://www.thirdgen.org/forums/images/smilies/iagree.gif)
Car: GMC 1500 P/U 4x4
Axle/Gears: 4:10
i've used 2 ton floor jacks since i've been working on cars. unless you plan on lifting a tractor or semi you don't even need a 2.5 ton jack. I've even used 2 ton jacks for very obsquer things such as taking tree stups out after all of ther root going horizontally from the tree. it works great for breaking the taproots off.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
And you'd have to lift the car right at the exact location under the center of gravity. Which might be under the flywheel.
Axle/Gears: 4:10
I try to find a spot on the frame towards the front and then torwards the rear and that will lift up one side and put jack stand under neith it. lifting a car and leaving the jack under the car to support the car is a death wish all it would take is a little bump and the car would come down on you. in which the jack stands you have more stability. the jack stand should be placed as closed to the hubs at the rear as possible with out disturbing the break lines and any other lines that might be in that area. and in the front as close to the a arms on the frame as passible
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I was playing with the hypothetical, by the way, not suggesting you actually try that.
Axle/Gears: 4:10
lol i would not try that because i've seen how unstble that is just by changing oil on some modern cars i just jack it up pull the pulg and let it down over the oil pan and try to get at the filter from the top
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
If your trying to get the whole car up on jack stands I'd say lift the front and put on stands and then lift the rear. I wouldn't try to lift from the sides. Thats just me, maybe it makes no difference but I would think it would be more unstable to lift from the sides.
Car: 1992 Camaro RS
Transmission: stock
alright thanx everyone, looks i can save some money and buy the 2 ton lol
Car: Camaros and Suburbans
Engine: V8's
Car: 92 GTA/ 00 TA
Engine: 383/350
The floorpan can't support the weight of the car. The jack, itself, would go through the floor before lifting the car.
Just this year I had an 07 Grand Prix GXP fall off of one of my jacks. I had just turned around to get the stands when it fell. The pictures are sickening. I ended up removing nearly the entire front clip and paying ~ $800 in parts to fix it. What sucks is that I was jacking it up so that I could get measurements of the engine cradle so that I could complain to GM that they don't know how to do an alignment. Trying to get $49 back cost me around $800.
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
Engine: V8's
Just this year I had an 07 Grand Prix GXP fall off of one of my jacks. I had just turned around to get the stands when it fell. The pictures are sickening. I ended up removing nearly the entire front clip and paying ~ $800 in parts to fix it. What sucks is that I was jacking it up so that I could get measurements of the engine cradle so that I could complain to GM that they don't know how to do an alignment. Trying to get $49 back cost me around $800.![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
Or I think I was just confused by his post. Anyway... I think this is a great and fantastic forum - tons of info and fun. Because of this site, I'm meeting other owners in my area!
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Some points that I thought were missed:
1. Make sure the handle is long enough. Jacking up the rear of the car by the differential, or the front by the crossmember, you'll appreciate one with a good long handle.
2. The capacity also says a lot about how much effort it takes to jack up a load. Jacking up the same weight with a 3 ton ($80 from Harbor Freight) jack is much easier than with a 2 ton jack.
Stay away from "rapid-pump" jacks unless you have a light race car or you weigh over 280 lbs.
Why is that? I have a rapid pump 3 ton jack and I love it. It pumps fast until under load and then it pump at the normal slower speed and isn't any harder to operate the handle.
Thanks, I learned in shop class (make that, in 1972), that you don't use floor pans to lift a car. I made the bad assumption that all "Senior Members" here on this forum such as our member - 84Z28406 - would already know not to do such a thing.
![Mad](https://www.thirdgen.org/forums/images/smilies/mad.gif)
Engine: V8's
It's a bad assumption to make, but I do know better. My comment about the floor was a joke. Meaning that if he did jack on the floorpan, it would at least bend far out of shape or go so far as the jack punching through the floor. Perhaps I didn't word it clearly enough, but rest assured, I know much better than to jack on the floor... The previous owner of my car didn't. ![Mad](https://www.thirdgen.org/forums/images/smilies/mad.gif)
...ouch!
![Embarrassment](https://www.thirdgen.org/forums/images/smilies/redface.gif)
At some point in life, somebody thought the oil pan on my 1984 would make a good lift point ...
![go crazy](https://www.thirdgen.org/forums/images/smilies/go crazy.gif)
Amazing what goes through people's minds.
Engine: V8's
Engine: V8's
Old Dudes Rule!!!
Everybody knows that we're the best as:
- Drivers
- Welders
- Mechanics
- Bench Racers
- Car Salesmen
- Chute Packers
- Track Officials
- Pit Crew Chiefs
- Diagnostic Techs
- Hub Cap Polishers
- Spark Plug Indexers
- Power-Wheelie Pullers
- Sponsor Fee Negotiators
- Powerglide, Lenco and 4speed Shifters
(...just to name a few). And most people know that when "Old Dudes" are not racing or raising havoc somewhere in the world, you can generally find us doing one or more of the following:
- Brain and General Vascular Surgery
- Re-defining the Basic Laws of Thermodynamics
- Astronomy
- Winning the Nobel Peace Prize (for actually doing something)
- Pre-Briefing the Next Space Shuttle Crew on Re-Entry Emergency Scenarios
- Making $1.25 per gallon - 160 Octane Fuel Available at Your Corner Gas Station
...Like I said; Old Dudes Rule!!
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
- Drivers
- Welders
- Mechanics
- Bench Racers
- Car Salesmen
- Chute Packers
- Track Officials
- Pit Crew Chiefs
- Diagnostic Techs
- Hub Cap Polishers
- Astronomy
Old Dudes Rule!!!
- Drivers
- Welders
- Mechanics
- Bench Racers
- Car Salesmen
- Chute Packers
- Track Officials
- Pit Crew Chiefs
- Diagnostic Techs
- Hub Cap Polishers
- Astronomy
- Drivers
- Welders
- Mechanics
- Bench Racers
- Car Salesmen
- Chute Packers
- Track Officials
- Pit Crew Chiefs
- Diagnostic Techs
- Hub Cap Polishers
- Astronomy
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
1 Post
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i say get the bigger jack. the smaller ones suck, because of the surface area a few walmart jacks have. i got the big floor jack with a diameter of about 6 inches and to top things off, i bought one of those polyurethane jack cushions so jacking up the car, it doesn't bend the metal as much, and conforms to the slightest shape, i cant really explain it. its pretty sweet..even got the polyurethane jack stand cushions. they mold directly to the jack stand top mounts. pretty wicked. and with smaller floor-jacks with the 2 and half inch diameter, (If its the one im thinking of That GM Good-wrench trolly jack) the small lifting point has less center of gravity, and can damage the rear lower control arm metal frame. ANYWAYS theres always a different preference out there, just a overlook. defiantly get at least a 1yr warranty. They will fail if you lower them too fast. blow seals. If i had another jack new, the first thing id do is bleed the air out for sure. peace out dude
1 Post
i got it at Harbor Freights. heres a link http://www.harborfreight.com/cpi/cta...emnumber=96306 its awesome
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
if you can afford the bigger jack get the bigger jack... hate to have it fail!
also, if you can afford it, get a jack that raises quickly with one pump.
i have one that will raise up to meet the car in one pump and then works like a normal jack using one pump to raise the car an inch or whatever
i cannot describe how nice this feature is
3.8TransAM
10-01-2015 07:47 PM
