does this combo look ok
Old 10-02-2009, 07:45 PM
kaosanddoom's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7
Axle/Gears: 3.43
been busting my a$$ to build this thing, and just thought i would get some info from more experienced fuel injection guys on whay they think of this setup, and whether or not it will play nice together. its in a 89 trans am gta 350 with auto.
<LI class=pdetail>Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 268/278, Lift .420/.442, Chevy, Small Block, Kit <LI class=pdetail>Hedman Hedders 68460 headers, Street, Full-Length, Steel, Painted, Chevy, Pontiac, Camaro, Firebird, 1982-92, 5.0, 5.7L
<LI class=pdetail>Cylinder Heads, Aluminum, Assembled, 64cc Chamber, 200cc Intake Runner, <LI class=pdetail>Intake Manifold, Stealth Ram EFI, Aluminum, Natural, Multi-Port, C<LI class=pdetail>Throttle Body, Twin 58mm<LI class=pdetail>Rocker Arms, Stud Mount, Full Roller, Aluminum, 1.6 Ratio<LI class=pdetail>also used .015 head gaskets to raise compress<LI class=pdetail>used holley fuel rail with afpr<LI class=pdetail>stock bottom end
after looking some more, the heads can handle way more cam, but not sure if i want to do it. what do you guys think, is setup good as is, or does the cam seem to small for the rest of the build. what crank hp #'s would you predict with this, and what do you think i could gain with the larger cam, heads will hold all the way to .6 lift. this car is not my daily driver, and actually sees very little street time, it is being built as an all around race car to be able to autox, drag, and road endurance race. any input is greatly appreciated.
Old 10-02-2009, 10:53 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: does this combo look ok
Might want to redo your links so they can be read.
Is the block a roller cam block?
Old 10-02-2009, 11:50 PM
Engine: 5.7
Axle/Gears: 3.43
yes, but i converted to hydraulic flat tappet, budget mandated. but i saved the stuff i took off so i could convert back if could ever afford a roller cam.
Old 10-03-2009, 12:37 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
268/278, Lift .420/.442, what is the @ 50 duration?
Your cam choice will do nothing to help the HSR breath given it will spin over 6K with the right combo.Even with the 1.6's rockers you only have .470 lift.
Could have put a ZZ4 roller cam in there; .470 / .510 (w/ 1.5's ) that would work better and reuse your old lifters.
Brand new take outs always on eBay for less than $140
The money wasted on the unneeded 58mm TB would be better spent on a roller cam .You have good heads , good intake but no cam to work with them
Old 10-03-2009, 11:39 PM
Engine: 5.7
Axle/Gears: 3.43
well i saved all the stuff to switch it back so no big deal. i thought that cam might be a little small for the setup, so i picked up 1.6 ratio rockers. guess that ain't enough. i will try and find a used roller cam and put that in instead.
Old 10-04-2009, 12:46 AM
Engine: 5.7
Axle/Gears: 3.43
how bout with a cam like this?
Cam Style
Hydraulic flat tappetBasic Operating RPM Range
2,200-5,700Intake Duration at 050 inch Lift
224Exhaust Duration at 050 inch Lift
234Duration at 050 inch Lift
224 int./234 exh.Advertised Intake Duration
282Advertised Exhaust Duration
292Advertised Duration
282 int./292 exh.Intake Valve Lift with Factory Rocker Arm Ratio
0.465 in.Exhaust Valve Lift with Factory Rocker Arm Ratio
0.488 in.Valve Lift with Factory Rocker Arm Ratio
0.465 int./0.488 exh. liftLobe Separation (degrees)
114Intake Valve Lash
0.000 in.Exhaust Valve Lash
0.000 in.
or would this be better?
Cam Style
4,000-7,200Intake Duration at 050 inch Lift
254Exhaust Duration at 050 inch Lift
264Duration at 050 inch Lift
254 int./264 exh.Advertised Intake Duration
312Advertised Exhaust Duration
322Advertised Duration
312 int./322 exh.Intake Valve Lift with Factory Rocker Arm Ratio
0.533 in.Exhaust Valve Lift with Factory Rocker Arm Ratio
0.555 in.Valve Lift with Factory Rocker Arm Ratio
0.533 int./0.555 exh. liftLobe Separation (degrees)
0.000 in.
is that in the right area
Old 10-05-2009, 10:10 AM
On Probation
Atilla the Fun's Avatar
Engine: several
Transmission: none
Axle/Gears: none
Cam Style
0.000 in.
Cam Style
0.000 in.
Definitely NOT! Your first cam was a fine choice for a driveable combo. 204/214 at 50 isn't much, but it sure feels good to drive at part throttle, and is decent at full throttle up through 4500 rpm. But neither of these two cams would even work for you. The ZZ4 cam would be an okay choice, but all that exhaust lift can pose problems. There's no harm in going flat instead of roller, except a bit less power. Nothing to stress over. If you want to go bigger tha your first cam, just go one step bigger, to a .442/.465 cam. That'll get you 5500 rpm in first gear, and 5000 rpm in third. It's not much fun under 2500 rpm, however.
Old 10-05-2009, 04:44 PM
Engine: 5.7
Axle/Gears: 3.43
yea, but i want it to be more of a topend motor. this isn't a dd that much, i really just want a fast race car. i think i am gonna try a zz4. hopefully that will do what i want.
Linson
09-25-2021 07:55 PM
InfernalVortex
04-20-2021 11:31 AM
norcalz28
Northern California
26
12-07-2016 12:49 PM
roysatikas
09-22-2015 08:15 PM
z28guy134
09-01-2015 11:50 PM
Quick Reply: does this combo look ok
