Installing Engine, where do you bolt to?
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
What bolt holes do you use when installing a new engine? When I pulled it, I attached chains to the heads. However, my new heads are AFR's and I cannot stomach the thought of lifting my engine and installing it by using my heads.
Thank you for your help!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Installing Engine, where do you bolt to?
longer intake bolts through chain link and into the intake bolt holes
Car: 1984 Trans Am, 1986 Fiero SE
Engine: 5.0 H.O., 2.8
Transmission: T5, M4 Muncie
Axle/Gears: 3.73 disc posi, CAVALIER AXLES!!
Another option would be to remove carb and build/make a plate that attaches to the intake where the carb goes that has provisions for lifting the motor........but this can cause intake manifold leaks......so I would temporarily bolt up the manifold WITHOUT GASKETS, install the motor, then remove the manifold and reinstall to specs with gaskets and such.....
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
He doesn't have a carb.
Use the intake manifold method listed above or just go ahead and use the accessory holes on the heads. It'll be fine.
Okay, so it sounds like I need to use the exact same spots for when I pulled it. Will this still be okay if I have the tranny attached when I put in th engine?
hectre13
12-11-2023 08:14 AM
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
