Smog pump removal belt
Old 09-07-2009 | 05:53 PM
formula's Avatar
Car: 89 GTA
Engine: 406
Transmission: 700 R4
Hey guys, I am deleting the smog pump. I went to Autozone and Advanced and gave them the part number for the belt (Dayco 968K6) and nothing came up. What part number are you guys using?
Old 09-07-2009 | 06:12 PM
Stephen's Avatar
Car: 87 GTA
Re: Smog pump removal belt
If you are pulling the smog pump off, why would you even want the smog pump belt?
Old 09-07-2009 | 07:48 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
your part # is correct if the car had a serp. set-up to begin with . but , the routing is different . i think the 968k6 is a little longer than stock . anyway ck. routing on main page mods. . there are several shown , make sure you get the right one ( one shows minus a p/s pump ) . good luck .
Old 09-07-2009 | 08:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you are serpentine, it doesn't have to be a delco, any belt will work - the part number refers to 96.8 inches long, and the 6 means 6 ribs - thus 968K6 - but they won't necessarily have that exact size - just get it close as possible (ie they might have a 96.5 in belt). I had to make 2-3 trips to get the right belt, as the 96.5 was a tad too long and I got a 96in I think.
italiano67
12-11-2016 09:21 AM
backtothe80s
09-05-2015 12:39 AM
mustangdmurder
08-21-2015 07:17 PM
3rdgenparts
08-08-2015 07:09 PM
mustangman65_79
08-07-2015 09:55 PM
Quick Reply: Smog pump removal belt
