Overhauling the 305 V8 (LG4) from '87
Car: Pontiac Firebird ´87
Engine: L69 305
Hey Guys!
I already wrote in an other thread about my car.. bought it from a guy near me.. he had it in his garage since 1996 and didnt move it for long time.
Car wont start when I bought it > carb. was reeeally dirty, fuel line was completely rusty in the back, and also the gas-tank wich I had to swap cause of the rust in the inside..
now the motor is running again, but sounds not too healthy - I guess also cause of the old oil.
So I want to overhaul the motor, but cant find a good thread about which parts to change... what would you change ?
and is there an onlineshop where I can order all that stuff?
>> I am sitting in Austria (Europe!!) ..
its not that easy for me to get those parts here :\
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Overhauling the 305 V8 (LG4) from '87
before you rush into an overhaul, let's focus on the rough running. No need for a nuclear missile to kill a mosquito. So, let's start with the basics. Does the check engine light come on when you first start the car, like it should? Does it stay on, like it shouldn't? If so, check the trouble codes. Next, How do the vacuum hoses look? Are they all dried out after just sitting so long? What's the timing set at? How do the plugs, wires, cap and rotor look? What's your fuel pressure? Look at all that, then report back, and we can go from there.
Engine: L69 305
Sparks are new (changed it last weekend) the old one´s were dirty.. but I guess this is of all the tries to get it run (before we didnt knew that there is no fuel comming throu the fuelline)
Also the oil looks worse, and I´ll change it and clean the oil-catch-thing (dont know the word in english)
some hoses in the front look dried out and porous.. thats why I thought it would be good to change them.. later or sooner I´ll have to do it..
Spark-Wires, plugs and Fuel Pressure is a good idea to check. I´ll check this!
The Errorcodes are empty. I checked this already when I bought the car, and after it run the first time at my place
thanks for your helP
On Probation
Engine: several
Transmission: none
Axle/Gears: none
dirty spark plugs can be cleaned and reinstalled. A wire brush works fine, as does careful sand blasting. Plugs get replaced for being visibly worn away, not for being dirty.
Engine: L69 305
yes you´re right, but with the car came in its trunk new sparkplugs, air intake filter, fuel filter, oil filter, break-kit (complete for rear)
so I just swapped the old ones.. and its a good idea to change 13 year old sparks against new ones I guess
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Well when i rebuild my engine all i did was replaced the main bearings, cam bearing, piston rings, lifters, and the oil pump but i wasted over $500 for that
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The LG4 should have a quadrajet carburetor, export version may be mechanical with no computer, and no codes to check. Does the carburetor have two (2) electrical connectors attached? One on top with two wires and one towards the front driver's side with three wires?
Either way that carburetor has been sitting for a long time without running. It will likely benefit from a rebuild to clean it out and replace old gaskets and rubber pieces inside. I'd also replace all of your plug wires and vacuum lines.
Engine: L69 305
900 € I payed for the car, here they sell normaly for about € 3.500++
Good condition with targa for ~ 7000 (from 1985++, older ones even more expensive)... so I guess those 500$ would be a good invest
and do you know a online store somewhere around, where I can get those parts?
I saw those rebuild kits.. maybe I´ll get one of those too.
... I think there are two wires.. but i´m not sure
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I got the parts from summitracing.com they will tell you excatly what you need too
1983, 1986, 305, camaro, carbureted, carburetor, change, engine, lg4, overhauling, plugs, quadrajet, recommended, spark, v8
