What engine sensor is this? (pictures attached)
#51
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: What engine sensor is this? (pictures attached)
The bog is likely either your air valve tension or your choke pull off. Your choke pull (the small vac canister, right front of carb) is designed to slightly open the choke blades once the engine is started. It will also prevent (and slightly delay) the air valves from opening until it loses its vacuum signal. Check it by depressing the plunger and holding your finger over the vacuum port on the back of it. The plunger should stay in until you release your finger.
The air valve is the flapper on top of the secondaries. It's controlled by spring tension. If the tension is too lose they open too quickly and will cause a bog. There's a tech article here on how to adjust and a diagram in the carb sticky, top of forum. A good starting point is tighten it until the valves just close then add 7/8 turn. It's a little tricky, you'll have to hold the tension with a small screwdriver while you tighten the set screw.
#52
#53
Sounds more like off-idle hesitation now. Your secondaries definitely won't come into play tinkering with it in the driveway. Does it drive ok as long as you baby the throttle?
Is this with the old carb back on, the one that hasn't been rebuilt?
You got it to idle properly at 700 or so rpms?
Check for trouble codes.
Put your timing light to it and verify that the timing is advancing as you open the throttle. It should look to be around 20+ at idle and the advance should increase as you give it throttle.
Tell us what it's doing and I can point you towards some things to check.
#54
If I baby it up, it'll run fine and at higher rpms I can hammer it and it won't stall out, it's only appearing off-idle right now...and badly, evne babying it up can be dicey.
#55
Classic symptoms that would prompt me to rebuild the carburetor.
You can try a few things before opening it up:
Is the MCS clicking when the key is turned to run? You should hear it click for about a minute, if the engine isn't started it will time off by itself.
You can cap all the vacuum ports on the carb/manifold except the rear one to the vac sensor and see if it runs better and check for leaks. Just don't drive it with the brake booster disconnected.
If you've got, or can acquire, a dwell meter or scanner I can walk you through adjusting the IAB. It may also help with some other diagnoses.
If you want to try to rebuild that one, we can help out.
Remember though that the shop was concerned about a weak distributor. It's probably not causing your off idle issues now but the ignition is the base from which all other adjustments are made. You should probably plan on replacing it at some point.
#56
Where can I pick up a dwell meter? Autozone?
I will try capping all of those ports to see what happens, at the least it would tell me if the leak is in the intake/engine area or not if I have one.
#57
You can get a dwell meter at AZ or most any of the others. Runs around $30. I used a dwell meter and a volt meter for years until I finally took the plunge for a scanner at around $250. Of course, with the scanner I can more easily amaze my friends.
#58
I am tempted to rebuild it, but I want to see if it's something else first. Especially since it idles so well...and until I took it off my 305 when got the "new carb" that didn't work with the 350, it was running very well. Of course this was nearly two years ago now (I got the "new" carb 1 year before the 350 went in and it ran good on the 305).
#59
It idles well, little high at the moment, but idles well. From idle, if I jump on it, it stutters pretty badly before taking off.
Also, I'm having an intermittant "popping" coming from my exhaust, sounds like the right side. Now, I do think that maybe I don't have one of my spark plug wires seated all the way so I'm going to let it cool down before I try and get at it and re-seat it. If this doesn't fix the popping issue, what should I look at?
Lastly, my check engine light came on. Code 41, and 43. Now, I have read in Alldata that code 41 could be a generic code that can be ignored. Code 43 bothers me however...and I dont like it one bit. Could it be caused by having one spark plug boot loose?
I thought for sure I"d have a rich/lean fault 45 or 43 but I didn't. Good old factory set carb lol!
#60
Code 41 is set by running the engine with the EST wire disconnected, which you do when you set the timing. I've never seen 43 before. I doubt a mis-fire would cause it, as I've run with plenty of mis-fires and never triggered it.
If the cause of your mis-fire is not readily apparent you may want to pull your plugs and check them. Running rich/lean can gunk them up. Next you can check each of your plug wires with an Ohm meter and verify each is reading about the same. Next would be inspecting and maybe replacing the cap and rotor. Have you recently had your coil and ignition module checked?
Could simply be your dist. When you pull the cap and rotor see if there's any side to side play in the shaft. Sometimes you can even see marks on the cap where the rotor has been hitting it. I looked at one a month ago and I still don't see how it was even running, it had so much slop.
#61
Pulling the plugs will be a weekend job. The distributor doesn't move enough side-side to rub. The cap, coil, rotor and wires are all less than 1 year old and are MSD (that that MDS matters, I just like throwing that out lol)
#62
#63
Car: 1984 Trans Am
Engine: 305 L69 (E4ME)
Transmission: NWC T5 1352-072
Axle/Gears: 3.73 (6HS)
I am still confused about what this is and what it does? I have read the post, but still not sure. Mine has a hose running from the top of this thing to a port on the intake manifold. There is no hole in the top of this thing where the hose fits on. Looks like a solid black plastic neck. Underneath it there is a brown wire clip to it and a white plastic stem that hangs down. The post said something about running the vacuum accessories. Is there a part number, what vacuum accessories is it running and what is the white stem underneath it for. Thank you....
#64
I haven't seen this before, at least that I remember. The 84 L69 TA would have had a vacuum operated air flap in the hood that this may be. Export models would have a mechanical qjet and used a vacuum switch for the lockup.
You say the hose runs from the top of this to a vacuum source but it's not connected and won't connect?
#65
Car: 1984 Trans Am
If you look on the first page of this post, under response #18 & #19 a couple of members (Ozz1967 and Shinobi'sZ) are having a discussion about it.
The hose is off in my picture, but normally it has a hose connected to the top that runs to a port on the intake manifold behind the carb. I was thinking it was the switch for the hood flap, but the way they talk about it in their response #18 and #19 it sounds like something else.
#66
Wow, I must have posted that without zooming into the pic. That's definitely not the check valve for the vacuum system. I'm thinking hood flap switch but it's been like 20 years since I've seen one. Hard enough to remember what I had for breakfast anymore.
#67
Car: 1984 Trans Am
Looks like you are right on hood flap switch. I started another post since this one was so old.
https://www.thirdgen.org/forums/tech...ystery-me.html
#68
Transmission Conv. Vacuum Switch. It helps the transmission to shift using vacuum pressure.
#70
Map sensor. It measures intake manifold pressure. It is suppose to connect to a vacuum line that connects to the rear of carb or tbi air filter riser/spacer nozzle. 100% accurate. The new carburetor was not adjusted for your vehicle and camshaft profile. Vac gauge should be showing 16-20hg with Q-jet (E4ME). Set should be 3 turns from seat on IAB screw, and 3 1/2 turns from seat on both front idle mix screws. That should give you a good Idle and starting point so you can get it dialed in or fine tuned.
Linson
08-21-2015 02:12 PM
