exhaust port on intake gasket,open or closed????
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: exhaust port on intake gasket,open or closed????
Well although the rhyme and reason to the exhaust cross over port eludes me it does apparently make a difference. Not only do some require a restrictor installed but it also makes a difference which side you install it on. So long story short the intake manifold gasket should have come with instructions that will say what applications had restrictors and on what side.
Car: 1986 Irocz
Axle/Gears: 3.25:1
It's a very simple deal. The EGR comes from the crossover ports on the heads. It feeds exhaust gasses into your intake manifold which also heats the manifold. If you don't want EGR or extra heat in your manifold, then block those crossover ports. The difference between open and restricted is irrelevant. It either flows exhaust into the intake manifold or it doesn't.
1992 Trans Am
05-10-2023 07:19 PM
LT1Formula
20
11-14-2015 12:02 AM
