Code 33
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Code 33
First of all, do a search, there has been more posting about the 33 error code than any other. Secondly, what car do you have? Are we supposed to guess?
Car: '87 IROCZ
Engine: 395 ZZ4
Re: Code 33
Well, I did not know that '91 V6s could get a 33 error code. Just about everything written about the 33 error code are MAF cars like mine.
Engine: 5.0L TPI F Code
Transmission: 5-spd Manual
Re: Code 33
On the 3.1L V-6 error code 33 equates to either the MAP or Low Manifold Pressure. If you know for sure that your MAP is good try looking for leaks in the manifold gaskets or hoses. There are many vacuum hoses that could cause this code.
Re: Code 33
its also map code stating to much air thats what makes me wonder about the iac i had it apart and tried a new one but that was before some other things but it ran fine passed smog the day I tried for the first time to give it some real gas under load going up na hill and from then on it started the diying routine and had to wait for it to cool down to make it home
Re: Code 33
if your iac is stuck open you will hear it hissing constantly. Not sure about your vehicle but I can stick my hand over the iac opening on my 88 350. If you can plug the air inlet of the iac then you will know for sure if its stuck open because it will stop hissing and might stall.
