383 crankshaft
383 crankshaft
Today there was a guy i know told me that i should put a 383 crankshaft in my 400 chevy small block cause it will make more low end torque so i was wondering is that true? will the 383 crank go right in without any machining? or is it better to just stick with a regular 400 crank?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 383 crankshaft
No
A 383 crankshaft is a 400 crank with the mains turned down to fit into a 350 block. The 400 has the longer stroke so putting it into a 350 engine can make a 383.
There's no way to increase the stroke of a 400 without using an aftermarket crankshaft and doing clearancing to the block.
A 350 crank or a 383 crank that's been turned down to fit into a 350 block can be installed into a 400 by using bearing spacers. A 350 crank in a 400 block is a shorter stroke and makes a 377. Large bore, short stroke makes good HP but not much more torque than a 350 would make.
LT1Formula
10-08-2015 08:34 PM
