dizzy hold down bolt clamp location?
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: dizzy hold down bolt clamp location?
Look underneath the distributor, on the passenger side, near the shaft. You will need a distributor wrench to be able to remove it without headaches
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Follow the shaft of the distributor down into the intake manifold, and you'll find it.
Why take it out though? You can just take thecap and rotor off to change those parts, you shouldn't have to remove the whole distributor.
junkcltr
08-02-2019 11:12 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
