Timimg set too High
Timimg set too High
Hi All,
Finally got the 83 z-28 with the 305 motor to start and stay running.Now I have the problem with the timimg set too high.I found TDC when I was doing
the intake replacement.When trying to start the car,the starter drags pretty good to the point that the battery is getting tired.I also noticed that when i took it for a test drive,that when i jump on it, the carb fails to kick in.I know all of this has to do with timing.Any suggestions?
