smog/ac removal,few questions
Car: 1989 rs
Engine: 5.7 350 4 bolt main
Axle/Gears: 3.83 10 bolt gm
i know this has been covered in this forum but i cant seem to find what i need,
im trying to eliminate both the ac and smog pump pulley,dont neet to worry about inspection,just want to eliminate both to clear up space in my engine bays:i am running power steering
just wondering if anyone can point me in the right direction of obtaining the parts i needed
i have heard of a couple options
option 1 put in a tensioner where the current alternator location is on the drivers side:anyone now where to get one
or
option 2 i have heard of getting brackets and tensioner to relocate the alternator to the passenger side, really like this set up but not sure where to get the brackets
option 3:i have also heard of having 2 belts instead of one belt,
any help would be greatly appreciated,normally i can find everything i needed in other threads but could not find anything
or
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: smog/ac removal,few questions
On the main page in the tech articles there's an article about smog pump delete. If you're removing your AC compressor you can get the bypass pulley.
Car: 1989 rs
i already know about the delete pulleys,longer belts,
i know about the faq page
but my question is how do i eliminate both pulleys smog and ac
i do not want to use delete pulleys
want to know what parts i need and where to get them
