What factors determine the power range?
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
or more specifically, low rpm power vs high rpm
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: What factors determine the power range?
Mainly camshaft. You can have identical engines with different cams. The powerband will be determined by the cam grind. Other things like heads, intake etc will only compliment or hinder the amount of power the engine will make in that powerband.
A typical street cam will have a powerband in the 1500-5000 range because that's where it normally operates. A street car doesn't need a powerband that starts at 3000 rpm while it always drives around under 2000 rpm.
A race car like mine has a powerband that starts around 4500 rpm and peaks around 7800 rpm. Going down the 1/4 mile where my engine normally operates, the engine rpms stay at peak HP in the 6500-7500 range.
Advancing or retarding the camshaft can move the powerband up and down slightly in rpm.
theshackle
09-17-2020 08:26 AM
sailtexas186548
08-24-2015 10:11 PM
