Alarm cutting out fuel pump?
Car: 1987 Firebird
Engine: 2.8l V6
There is no #2 Fuse in my 87 Bird.
Took out the fuse box, There is no connections to the #2 Slot.
Would an alarm installer wire it this way?
If so what color lines should run into the #2 Slot?
And what do they run to?
I guess what im asking is what does an alarm kill? Fuel pump?
Car: 83 z28
Engine: vortec5.7/predator/msd/lunati/teamg
Transmission: th350/transbrk/rev-manual v body
Axle/Gears: Ford 9 inch 4:56
Re: Alarm cutting out fuel pump?
recently I worked on a 05 tahoe where the alarm (factory alarm) shut down the ingnition system, door lock/unlock,windows, but the fuel pump still ran,check your fuel pump relay and fuse first,
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
