Tickling the rev limiter
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Got a quick lil question, I put my Iroc sideways a lil too fast and I tickeled the rev limiter, I think I even hit the limiter, not sure too loud of a car haha. My question is, is that gonna hurt my motor at all? I got an msd on the way to help me with that
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: Tickling the rev limiter
Huh? I don't understand your question, you put your car sideways? Were you drifting or something? Do you have a rev-limiter on your car? If so I don't see how you could have hurt your motor, that's why you installed a rev-limiter, so you wouldn't cause damage to your motor. And if you didn't install a rev-limiter, well our cars didn't come with rev-limiters so I dunno what you were "tickling" the red line? If that's the case then read this
https://www.thirdgen.org/forums/tech...ml#post4189772
Engine: Carb 355
Axle/Gears: 4.11
No i wasnt drifting i revved it a lil and let go of the clutch too quickly on perpose and then turned the wheel to go sideways and in doing so i jus about tached out. and i dont have the msd yet with the rev limiter its on its way to being installed
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Ah alright, yeah, it's very easy to do that any time you spin the tires. Burn-outs often occur above the 4000 RPM mark for me.
Nah, I doubt you did damage, as long as you didn't spend much time revved way up there then you should be fine.
Read that other post I linked, it has a lot of helpful information on redlining, what it damages, and how you're not very likely to damage anything unless you're very hard on it.
Engine: Carb 355
Axle/Gears: 4.11
Ok good haha Im worried as hell with it cause the motor only has like 8000 miles on it and I dont wanna hurt it at all
RedLeader289
05-28-2019 01:47 PM
