best double roller timing chain worth it?
1 Post
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Later this summer or fall I will put a LS1 CAM into my '87 305. How much benefit would be gained from adding a double roller timing chain?
http://www.jegs.com/i/Comp+Cams/249/2136/10002/-1
Last edited by scooter500; 06-01-2009 at 06:25 PM. Reason: added link to timing chain
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: best double roller timing chain worth it?
They're not as quiet as a factory style chain but you'll never hear it anyway. It also won't last as long as a factory style chain.
It will be more than strong enough and much better than a factory chain. Just don't expect it to last 20+ years. All chains and gears will eventually wear out or stretch.
You don't have to buy a Comp Cams chain. A good Cloyes chain will do just as good. Don't buy the cheapest chain you can find. The offshore stuff isn't that great.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Stephen must have been asleep. You can't put an LS1 cam in a 305, and any Cloyes chain will far outlast any GM chain.
1 Post
Car: 1990
Axle/Gears: stock
which one do you suggest? i know you wrote Cloyes but which one would you suggest for a slightly modified 305?
i went to a number of sites and saw a really strange range of prices.
this one was http://www.autopartswarehouse.com/se...90%20Chevrolet or is high - i think.
but this site was really low. http://www.rockauto.com/dbphp/mfr,CL...hrust%2BButton
does anyone know why the big difference?
Car: 87 IROC L98
I'm not into the LSx stuff so I don't know what fits into what.
Like everything else, there are chains of different quality. An entry level Cloyes chain kit will do fine especially for a street engine.
http://www.jegs.com/i/Cloyes/220/C3023XSP/10002/-1
The better kits like a true roller just deduce friction
http://www.jegs.com/i/Cloyes/220/9-3100/10002/-1
1 Post
Car: 87 Camaro Z-28
Sorry, I have an LT1 cam waiting to go in my '87 305 later this summer.
JEGS add says a double roller timing set could add 10hp - nice!
I noticed the COMP set is only ~ $10 more. Is this the better set?
Car: 87 IROC L98
You're probably paying for the name.
junkcltr
08-02-2019 11:12 PM
