Update to: Your Best Guess
ECM/or chip - Ing. Coil - Pick Up Coil in the Dist.
If you had to make a guess a on one of these over the others going dead after getting to normal running temp. and restarting cold no problem which would it be.
I have changed out the pick up coil module tested ok tried a new coil once it got hot and died no change ( fuel psi fine holding and no drop ) so having changed computer and still having half the original problem I gota think that the guy who said in one of the threds on this about his chip being bad is the problem now but now heres is the real problem where can I get just a plain stock chip for a 91 3.1 v6 manual trans. the dealer near me is a hit and miss deal anyone else have some input, thanks everyone again, George.
2012sergen11
10-13-2015 07:38 PM
