Stuff in the Fuel Tank
So please help if you can.
I was having a hard time with my 83 Camaro, I could drive it but shortly after it would sputter and die, as if it was flooding. I thought it was the Carb, per some family advise, so i had my Carb rebuilt. They guy that did it said it was full of crap so it was good to clean it out.
I took it, ran great for about 30 min then the same thing. Wen and replaced the fuel pump and filter, plugs and wires, still acted as if it was flooding. I never smelled gas so i did not think i was flooding.
Finally took it to a friend who looked at it and he found more stuff in the carb. The only thing i can think of is the gas tank has crap in it.
How would i clean and reseal my tank? or would it be better to get a new one?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Re: Stuff in the Fuel Tank
To clean the tank you'd have to remove it and drain it
Wash it out with kerosene or diesel fuel
Get a junk yard tank to reduce down time
While the tank is out it would be a good idea to unhook the fuel lines and blow compressed air down them to blast out contaminants
Car: 92 RS
Engine: 3.1 V6
I am having the same issues as custom13 but mines a 92 and there is a lot of rust in the tank would i be able to reuse it? will the rust come back?
Car: 91 Camaro
Engine: 5.7Fl V8 350 tpi
Transmission: 700R4 Automatic
my car won't start and the people i ask about it range from junk in the gas tank to a bad igniton module. so would that help just like a tune-up cleaning out the gas tank like that. would it help my car just like changing out the plugs wire and dist rotor and stuff.
beachrodder
08-25-2015 08:05 AM
AkDrifted
08-17-2015 07:45 PM
