gas tank capacity
Car: 1991 Trans Am
Engine: sb chevy's.
gas tank capacity
i'm only able to fill up with 8.5 gallons. i thought our fuel tanks had the capacity of 15.5 g. Do yall know what could be causing this?
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: gas tank capacity
you started out with half a tank?
ha ha im sure thats not the case, but have you ran in it out of gas and then tried to fill it? I had a similar problem with a lebaron that I used to have and I found out later that I had a huge dent in the top of my tank.
Were you using a fast pump, if the gas tank breather tube is dented or somehow plugged it could cause the gas to back up the filler tube and shut the pump off.
Car: 1991 Trans Am
Engine: sb chevy's.
Well the car died at the pump cause it was past E. Also i've been under the car to see if it was dented a while back and it wasnt. Everything seemed good. I know it can't be a different tank either cause its the original tank and i saw the part #
Bohemian
08-15-2017 05:11 PM
