Help identify bosch injectors(PLEASE)
Car: 1987 Z28
Engine: LG4
they are 100% brand new bosch injectors from a 2009 ford f-150 with 5.4L
im trying to find flow and pound rates...i do know id have to get the adapter harness to run them
please im hoping someone can tell me what these little guys run
thank you in advance
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
Re: Help identify bosch injectors(PLEASE)
if no one is able to help you, try messaging southbay08 and ask him/her.
Car: 1987 Z28
Engine: LG4
they are bosch....due to i pulled them from a bosch box LOL
but anyways...someone in another tread found they are 27lbs bosch III injectors....sounds good right? Well since the new 5.4 truck motor has 2 intake valves the nozzle is made to split the mist....in a LT1 it was stated it made it idle like crap...im wondering since lt1 is sequential and more presize and TPI is batch injection and more like a carb would it matter if the mist pattern isnt perfect?
to those who dont know what sequential and batch is:
Lt1 sequential fuel injtion = fires per cylinder
TPI batch injection = fire 4 injectors per side of motor at one time.....yes waste of fuel kinda like a carburetor
do you know if they came from a stock engine? how much hp will you be running?
You can identify a bosch injector by the part number.
It begins with a 0280......
By the way if you need the adapter harness we have them in stock so feel free to contact us either by PM, email info@southbayfuelinjectors.com, or 516-492-6504
