Need help putting my engine back to geather.
Car: 1985 Camaro
Engine: V6
Well, I decided that I needed new head gaskets because i was loosing oil and coolant, turns out that I indeed needed the new head gaskets. Now I have my entire engine torn apart and I am not 100% on where everything goes. Are there any tips on putting the engine back together from the block up? Can someone post some detailed pics of a v6 engine setup? Also if anyone is near me (Grand Rapids Michigan) wanna come over and bust some knuckles? Thanks.
Re: Need help putting my engine back to geather.
While I have never put a v6 together....run out and get yourself a repair manual for the car. A Chilton or Haynes will work. Should be able to find one at Autozone or Advanced Auto. If you could wait till monday, I may be able to make it down that way to lend a hand.
Car: 1985 Camaro
Engine: V6
I'll run to autozone and pick up a book on it. I will keep working on it Sunday, I am pretty sure I will still need quite a bit of help come Monday, so it would be very appreciated if you would come down and help me out a bit.
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Well if you need anything or have any questions ive torn down 2 2.8s and have all the factory manuals covering them. Unfortunetly my 2.8 camaro is 6 hours away so i cant really send you any pics of it assembled but i can provide just about any other info.
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
I didn't know there were any other guys in the GR area on here. I would help, but I never worked on the v-6's. sorry.
Car: 1985 Camaro
Engine: V6
Hey any help that I can get with someone that has basic knowledge of how an engine is assembled would be of great value to putting the car back together.
db057
08-11-2015 10:11 PM
