300hp 350??
Car: 83 firebird/camaro conversion
Engine: carbed 350 very mild build
Transmission: th350
Axle/Gears: 3.42 posi
300hp 350??
need to no what my options are for making around 300hp out of my 350 i wish i new what the motor came from but i dont all i can do is supply a picture these are old pics by the way so dont flame me to bad they were before i got the car
Transmission: th350
Re: 300hp 350??
wow nobody lol not even comments on my junk
1 Post
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
Re: 300hp 350??
most stock 350 have 260 hp. so with the aluminum intake and headers you should be very close. the eldelbrock 500 cfm is killing it though. plus, it's according to what the engine come from. did it come out of a truck or a car? the crank, cam, heads play a critical role. how many miles are on the engine? is it stock or is it modified?
Transmission: th350
Re: 300hp 350??
1 Post
Car: 1986 Iroc-Z
Axle/Gears: 342
Re: 300hp 350??
how do you know it's a 350? the casting number is behind the distibutor on the passenger side. if you can remove the distibutor you'll be able to see it with a flash light. or just cram some pladoe on the back of the block and peel it off real easy and maybe you'll be able to make out what the number is.
Transmission: th350
Re: 300hp 350??
1 Post
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: 300hp 350??
pop the valve covers off and get the casting numbers.
are there any markings on the intake manifold telling what brand or any numbers?
Get a carb spacer at least 1".
Get new fuel filter.
New air filter.
Try those once you get the block casting numbers to make sure its a 350.
New air filter.
Transmission: th350
Re: 300hp 350??
New air filter.
New air filter.
