cam ate up a lifter, what now?
Car: 01 Trans Am WS6, 99 Dodge Durango
Engine: Built 6.0, 5.2
Transmission: T56,AOD
Axle/Gears: 3.55 9", 4x4
My cam ate up the intake lifter on cyl 1. The plate that holds down the lifter guide plate bent and my lifter turned sideways and got eaten up. I was able to pull the lifter out and used a magnetic pen to pull out the roller portion of the lifter. What are the odds that I'll have to replace my cam and what can i do to get the metal out of my motor w/o having to put the motor out again.
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: cam ate up a lifter, what now?
nothing you will need to replace the cam and tear down that engine to get all of the metal out
dimented24x7
09-06-2015 03:51 PM
