Air intake Ducting
Car: 89 Iroc-Z Ragtop, 2012 Toyota Hilux
Engine: 305ci V8 TPI
Transmission: Both Auto's(Wife can't drive stick)
Air intake Ducting
Hi I was wondering if anyone has done the following?
I am looking at cutting two big holes one in each of the bottom of the air filter housings & then running some wide diameter plastic ducting from the air filters down to just behind the driving lights. My reason for this is obviously cold air into the engine without having to change all the plumbing under the hood for a cold airbox.
My questions are 1. how would I attach the ducting to the underside of the air filter boxes and 2. would this block cold air from getting into the engine compartment for cooling of the engine etc?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Pretty sure I've seen a member who has done that. Fabrication forum, perhaps? TPI forum? Don't remember where it was posted.
Car: 1990 iroc-z
Engine: 350 tpi
Axle/Gears: 3.23 posi
Re: Air intake Ducting
dude i just did this exact same thing to my iroc the other day and man was she pulling air it was awesome lol
Have you got any pictures? Would love to see how you attached them
Car: 1990 iroc-z
Engine: 350 tpi
i'll try and get some up soon but my buddy didnt latch my hood all the way and it folded up on me so its stuck at his place all bent up so it might me awhile but man oh man its a sweet easy upgrade from our stock restrictive air boxes she was pulling crazy air lol it was SWEET!!
Car: 87 GTA
https://www.thirdgen.org/technical-articles
Which will lead you to 3 articles.....
https://www.thirdgen.org/ramair
http://www.geocities.com/MotorCity/S...49/ramair.html
http://userpages.xfoneusa.net/~davidlt/air_intake.htm
Car: 1987 Red IROC-Z Hardtop
Engine: Bolt on 305TPI
Axle/Gears: 3:23
WOW i didnt even know you could do that!!!! endless possibilities eh? im definitly doing that tomorrow. it sais it pulls harder at high speeds.. how much hp would come out of that roughly?
1 Post
Car: 1990
Axle/Gears: stock
How about what is on the Home Page of ThirdGen.org, in the Technical Articles section?
why not notch the hood and run a forced type of air that way. have you ever seen one done that way? that way you dont clutter the engine compartment and get the air from outside the restriction of the engine compartment.
you sure look like you know the topic.
Axle/Gears: 3:23
alright heres a little update.. i went out and got the ducting. seems kinda thin but it looks like itll do. you really gotta make sure theres not access ducting because i ended up with a little. anyways i got one done now im onto the other side. for the first one it took alot of modification to the ducting i even got 9" and it didnt fit over the bottom of the air filter or the fog light tubes. took alot of duck tape :P but i made it work. hopefully it works good ill try to remember to post pictures.
1992 Trans Am
05-10-2023 07:19 PM
