Any difference between a '78 and '86 Small Block??
Car: Firebird 1987
Engine: 5.0
I have the chance to buy a small block V8 from a 78 Camaro - cheap. I'm thinking of buying it cleaning it up/rebuilding it just to give me something to do.
I just wondered whether I could potentially put it into my '87 Firebird if I ever had to? I appreciate that the sumps may be different, and I would need to transfer all my ancillaries etc, but would the basic block, engine mounts etc all be the same??
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Any difference between a '78 and '86 Small Block??
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Also, the oilpan isn't a problem, keep the '78 pan with the '78 block. The '78 heads won't accept your stock exhaust manifolds, but they will accept almost any headers for your car.
Car: Firebird 1987
Engine: 5.0
Thanks for the replies.
If I did ever fit it to my car, I think I'd change to headers in any case, even if it was just so I could get to the plugs easier!
Could I change the rear seal to a two piece type? Presumeably GM changed it as a 2 piece is better?
Also, I was going to do a search later, but if I changed to headers, does that mean I could remove the smog air pump and all teh associated plumbing? The smog rules are different over here, and an 87 car doesn't need all that stuff.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Smog pump. Do remove it, but save it, as laws do change, especially emissions laws as global warming gets more attention. Take photos first, don't butcher anything, label things, etc. Second, the '78 is 2-piece rear seal, which is not better. The '87 is 1-piece, which is better, and the '87 uses a roller cam. The '87 intake will require a bit of work to bolt to the '78 heads. GM went to the 1-piece to reduce warranty claims about oil leaks from the rear main seal. Now, if you're going to play with the '78 anyway, first be sure it is the 350, not a 305. 350 has 4" bores, 305 has 3.736". If the block has no damage, then consider stroking it. Doing a 383 couldn't be easier. and a stroker will need good-flowing aftermarket heads, preferably aluminum. Then you're on track for well over 400 horses.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Your '87 305 heads are better than the '78 350 heads. Putting the 305 heads on the '78 block will solve about 75% of your compatibility issues.
1-piece rear main seal is better than 2-piece. But, that doesn't mean 2-piece is "bad". You will need a different flexplate, that's all.
The '78 will have the dipstick on the right side of the engine (looking at the engine from the front of the car). Stock intake manifolds get in the way of the dipstick tube. Headers solve that problem.
Car: Firebird 1987
Engine: 5.0
The engine I'm looking at is a 305, but that's ok with me. Its cheap, and I'm just getting it as a project to keep me busy with the added bonus that I could use it in my Firebird IF my original engine dies (it's done 180000m, but otherwise runs ok at the moment). I've done loads of head jobs before, but I've never rebuilt a complete engine, so it'll be interesting.
Thanks for the info.
Engine: LS1/LQ4
Silly me, assumed you were talking about a '78 350. . .
But, the '87 heads very likely are better than the '78 heads.
theshackle
03-05-2017 06:37 PM
Mickeyruder
09-02-2015 02:45 PM
BlackphantomZ28
08-22-2015 01:00 PM
