Ignition switch is Jammed...I Think
Car: Eighty-Six
Engine: 5.0L 305-TBI
Transmission: N/A
Axle/Gears: N/A
Ok. Basically 2 weeks ago I go to turn of my car after getting home from work, and I couldnt turn the ignition back. It was stuck or jammed it seems. I had to let the car run out of gas order to let it cut off. (OKAY, your probably saying just disconnect the battery terminal..well i had no idea how to at the time) So my car is been in the same spot for 2 weeks in the "ON" position. Somebody tell me something, anything,..advice/criticism is welcomed.
1 Post
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: Ignition switch is Jammed...I Think
You may have something broken in the column. Happened to me on my S-10. Spring broke and jammed into the gear that allowed the ignition switch to change positions.
Car: 86 Camaro
Engine: LG4
tglennon11
Interior Parts Wanted
09-11-2015 10:25 PM
