what cam??
Car: 1983 firebird
Transmission: t-5
Axle/Gears: 10 bolt, locker, disc brake setup.
what cam??
i have a older gm 350 crate motor around 97 it only has 20000 mile and i have a big intake and 600 cfm carb. i just wanted to know what kind of cam i should get i want to go as big as i can with good street manners and power for the track.
what do you think?
what do you think?
Re: what cam??
You can Call up Tech at Jegs and they will ask you questions about what you want for performance. and what else you plan to do to your car and give you a list of cams that fit your application.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Also need details such as the heads on the engine, as many of those crate engines don't benefit from a lot of cam.
What intake? Compression ratio?
Car: 1983 firebird
Transmission: t-5
Re: what cam??
The compresion is 9.5 and the intake is a Weiand #7530 Team G.
i dont know what size heads, stock i guess.
1 Post
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: what cam??
If it's really stock heads (pull a valve cover, get a casting number), then a Team G intake is a severe mismatch. You'd be better off with a dual plane.
If it's stock heads, you're limited to lift under about .480". The list of cams that fit that lift, and run in the powerband of the single plane intake you've got are very very slim.
Car: 1983 firebird
Transmission: t-5
Re: what cam??
well i have an old set of steel corvette heads 2.02/1.60 i could put on. could i get a cam with more lift if i do that? what kind of dual plane intake should i get with that combo?
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Re: what cam??
given the number of different crate engine combos available from GM (aka: truck replacement, performance crate...) there really isnt any way for us to guess which heads you have. if you remove a valve cover and copy the 7-digit casting number down, then we can offer more specific advice. however if i had to venture a guess i would say it probably has some form of swirl port head. That means the heads are optimized for low end torque and fuel economy, the intake you currently have is optimized for top end power, hence the mismatch.
check out something like this instead
http://store.summitracing.com/partde...0&autoview=sku
-Zander
-Zander
Engine: LS1/LQ4
Again, need the casting #'s. Depends upon how old, and "Corvette" doesn't always mean much.
Car: 1983 firebird
Transmission: t-5
Re: what cam??
i will go get the casting number tomarrow.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: what cam??
in general the gmpp hot cams have always made decent power
with just about any sbc heads. seems very popular with the low budget mag. racers
made some good power with vortec heads and dual plane intake,
Super Chevy buildup
Super Chevy buildup
Car: 1983 firebird
Transmission: t-5
Re: what cam??
the casting #s are 83417869 for the ones that are on it.
the 2.02/1.60 heads are 3991492.
Engine: LS1/LQ4
Doesn't look right. Can't find anything like that.
Those are genuine LT-1 heads. Straight or angle plug? Not bad heads for the time, probably worth considering.
Car: 1983 firebird
Transmission: t-5
Re: what cam??
they are angled plugs.
so what cam would go good with that setup?
GM 350, stock bottom end
9.5/1 comp.
2.02/1.60 heads
edelbrock air gap dual plane intake
headers
aluminum roller rockers
and now i have a edelbrock carb. 650 cfm.
9.5/1 comp.
2.02/1.60 heads
headers
Car: 1983 firebird
Transmission: t-5
Re: what cam??
i checked the casting number again thats the right number, so i dont know.
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
Re: what cam??
Try Comp Cams XE268H. You can use it with a stock converter and has decent idle. Would recommend the K kit so all you valve train parts match.
