tach wire help needed asap
1 Post
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
ok i got my summit ignition in and running all the wires. now the ylw wrie that reads tach has to be put with my stock tach wire by bypassing the dizzy tach spot straight to the ign. tach wire. how can i get the cap (brown cap that connects to tach port} apart without messing it up in case i wanna put it back into the dist? do they make a connector for it or do i gotta cut it? i dont wanna cut it. any help is apreciated
