eletric fuel pump help needed fast!
1 Post
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
ok i put a electric inline pump on my car wired everything up corrctly, and installed there relay kit. now my pump keep losing power. i turn it off and itll start up again after a few mins. im thinking its the relay. how do i wire it up without a realy? i have it on a toggle now. thanks
Re: eletric fuel pump help needed fast!
What source did you use for the main pump power? What wire size?
What signal did you use to control the pump relay?
How is the pump motor grounded?
beachrodder
08-25-2015 08:05 AM
