Drift Carb Vs TBI
Car: 1984 camaro z28
Engine: LG4
Axle/Gears: stock
Drift Carb Vs TBI
Buying a L69 84 camaro w/ 5spd.
Was wondering if when im drifting if im going to get weak lag from the carb, like bad throttle response or if it is just a different engine config i'd have to get used to.
a few people have told me carb is better, and a few have told me it will cut out cause the gas will be sloshing around.
I can either put my holley 600cfm carb on it...
or our junkyard has a car with the TBI still that i can swap it too....
which would be better?
and how hard is it to swap to TBI?
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Drift Carb Vs TBI
They sell different style floats for different application don't know if theres a pacifically one for drifting . . . just someting to look into for a carb
Engine: LG4
Axle/Gears: stock
good info, i will look into the alternate float assembly's... anymore suggestions much appreciated.
"Drifting" with your Camaro (steering with the rear wheels) will impart a lot lower lateral G forces than the real IROC cars experienced by NOT slipping the rear wheels. They ran just fine with carburetors.
Billy Decker
09-04-2015 03:46 PM
bad, car, carb, carbureted, carburetor, carburetors, cuts, drift, drifting, engine, float, good, holley, motor, tbi
