vats module bypass
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: vats module bypass
CAPS LOCK IS NOT YOUR FRIEND!
Tends to signify yelling on the forums. Last time i checked those bypass boxes only came with 2 wires, any way to post a pic of it? where did you get it? is it the proper resistance?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
ok i dont know why you need the positive and the ground other than the LED, the signal wire has to attach to the TINY white wires concealed under your plastic cover along the steering column.
Is it the proper resistance. If not your screwed
