Valve Springs
Car: 1984 Camaro Z28 T-tops
Valve Springs
One of the heads I am looking has a valve spring pocket of 1.550". Do I need to use a 1.550" external diameter spring, or can I use a smaller spring? The cam kit I'm looking at has 1.254" springs. Will these work or will I need to get just cam and lifters and purchase the springs separate? I tried to search, but not much came up other than spring rate and seat pressures.
Re: Valve Springs
Comp cams extreme energy 268 solid flat tappet. http://store.summitracing.com/partde...76%2D4&FROM=MG
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Valve Springs
You could use that spring in the larger pocket, or choose a similar larger diameter spring.
Why do you want a solid lifter cam?
Re: Valve Springs
I've been told that they make a little more power vs hydraulic flat tappets at similar advertised durations. Desktop dyno, for how little I trust it seems to confirm it. I've been told theyre more stable than hydraulics since they don't pump up but I doubt that would be a problem at the rpms I'm likely to see. I know solids need to be periodically re lashed, but I don't mind this so long as it's not every saturday.
Engine: 383 Carb
Transmission: 4L60
Re: Valve Springs
With such a small cam you won't see enough difference in power to be worth the extra hassle of lashing the valves periodically.
Re: Valve Springs
Hmm, then there's little point. I'd go for a bigger cam, but don't want to spin the stock cast crank past 6000. Thanks for the help. Hopefully you're this helpful for my other no doubt simpleton questions that I'll be asking in the coming months to summer.
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Valve Springs
IMO you'd get more by converting to a hydraulic roller, and not have to worry about the periodic adjustment or "breaking in" the cam.
Re: Valve Springs
I would love to go hydraulic roller but can't afford a the retrofit lifters. Does the 3970010 block have bosses to drill and tap mounting holes for a stock roller lifter retainer? If you don't know I'll check, but it'll have to wait for spring. If it does, I can look for a set of rollers and a retainer from the junkyard. Would I need anything past the lifters and retainer themselves?
Engine: 383 Carb
Transmission: 4L60
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Valve Springs
not to mention the block is not clearanced for the lifter tie bars either
Re: Valve Springs
the ones that go from one lifter to the other and are held down by the lifter retainer.............for the newer style like he is asking about since the 3970010 blocks are not equipped with the boss's for the bolts that hold the retainer in place............he is better off gettin a set of retrofit roller lifters......ive seen em for 240.00 for a decent set at www.competition products.com
Re: Valve Springs
ahh i see...dog bones or gm's term...tie bars.lol same thing.i just got done puttin a newer style cam in an older block with retro fit lifters.........and used a newer style timing chain as well............ cant wait to fire it up
Re: Valve Springs
A roller cam and it assorted supporting parts are out of my price range at the moment. I'll snag a hydraulic flat tappet for now and wait on a hydraulic roller for when I eventually build a 383.
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Re: Valve Springs
I would still go with solid if I were you, they do make more power, and valve lash adjustments are no big deal, people will make it seem like you will be adjusting them daily, but in reality, you will set them once, then check them with every oil change, the valves will not just come out of adjustment on there own, the only way you will see signifigant changes in lash is if something breaks.I think they got there bad rep. when gm put them in cars with stock valvetrain way back in the sixties, I could see if you were using them without polylocks they could be a royal pain.
Why such a small cam? Gm cranks will easily spin over 6000 rpm, it is the rod bolts you need to worry about. I would consider a comp 280 cam, you probably will not have to spin it much past 6000, and you will actually be able to hear it!
If you want to use a 1.2 spring in a 1.5 pocket, you will want to use a spring cup to positively locate the bottom of the spring, you will not want it dancing. If you do decide to go with a bigger hydraulic or solid cam, I would use a 1.4 spring, a bigger spring will last longer than a smaller spring of the same specs.
Re: Valve Springs
I've decided to just buy the heads assembled. Probably some patriot 190s unless I hear something really bad about them. As for the cam, I'd like to go bigger, but am afraid of passing 6000 rpm on the stock lower end. You say the biggest issue is the rod bolts. If I throw a set of these in, will that hold her together to 6500? http://www.jegs.com/i/ARP/070/134-6003/10002/-1
If so, then I'll go for an XE284H, XS274S, or an XS282S, though I think the last one pushes the limits of 6500 rpm. How much extra horsepower will the solids give me over an equivalent hydraulic? As for relashing, once an oil change is half as often as I'd be willing to do it. I just don't need the bottom end blowing through my oil pan.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Valve Springs
Really not much point to running a solid cam if you're not spinning over 7 regularly. Especially with the way Comp grinds the ramps on their XE series hyd. rollers. The improvements would be negligable.
Re: Valve Springs
Not getting a roller, solid or otherwise. At the moment, the only possibility is flat tappet, unfortunate though that may be.
Car: 91 rs
Transmission: th350
Re: Valve Springs
I would go solid flat tappet over hydraulic flat tappet, hydraulic roller is a real good way to go, but I think his budget dictates a cheaper set-up, a solid flat cam is superior to a hydraulic flat cam even below 7000, it is the agressiveness of the lobes, with a cam of 280 duration or larger, I really think solid is the way to go, valve lash adjustments are not nearly as frequent as people will have you believe, and they have a lobe profile not too far behind a hydraulic roller, for a hole lot less cash.
Are we comparing a solid flat tappet to a hydraulic roller? Not really a fair comparison due to the cost difference, a solid flat tappet will make nearly as much, maybe more power, for a hole lot less, solid roller to hydraulic roller there is no comparison at all!I thoght we were comparing hydraulic flat tappet to solid flat tappet, in that case, I would go solid if I wanted to make good power, but those hydraulic lunati voodoo cams seem to have a good lobe, and are priced fair, that may be something to look into as well.
