alternator crackling
Car: 1984 Camaro Z28
Engine: 305 H.O
well when im under the hood and give it some gas i hear my alternator wind out then make a weird crackling noise.... u can really hear it when i down shift in second its really embarrassing to be honest does anyone have any ideas? u think its just about to go out on me or somethings loose?
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: alternator crackling
The bearings may be about to go out completely. Just before my clutch fan stuck it made some kind of crackling noise.
Take off the fan belt and check the bearings for wear/noise.
Engine: 305 H.O
im gonna replace it i have a lifetime warranty on it but i like to learn about weird noises and what causes them for future reference thanks... and i have an electric fan so dont think its my fan clutch
Duh.. When I mentioned my clutch fan noise it was because both items have bearings that can fail in the same way, giving off similar noises.. You wouldn't need to take off the belt to check the fan clutch bearings. Get the bearing?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
SOUND ADVICE
To isolate the sound take a piece of hose and use it like a stethoscope.
WATCH OUT FOR MOVING PARTS !
Youll find the source.
Happy Racing!
If People Drove Any Slower Theyd Be Going Backwards.
Happy Racing!
Engine: 305 H.O
yeah i did that i know its the alternator for sure but i dont know whats causing it do do that well im gonna have a mobile mechanic come out and check it out along with my timing and carb adjustments.... maybe he will have an answer hopefully
Car: 88 GTA "Cocaine"
Engine: 350 tpi
is the belt 2 tight?
are you sure its not the water pump
is the altenator pulley in perfect alignment with the rest of the pulleys
just some of the things I would think of
Engine: 305 H.O
the belt isnt too tight the water pump is brand new and yeah they all line up fine i looked.... i know when i was putting in my water pump and i had to loosen the alternator and take the bracket off well i didnt disconnect the negative on my battery and sparked a little but it shouldnt be a problem and when i put a different one in it made the same noise anyways
raymondandretti
09-27-2015 06:43 PM
