To Much Lift For These Springs??
Car: '89 IROC-Z
Engine: LSx
Hey everyone, I got an 86 LB9 with the summit G5000 cam/lifter kit. http://store.summitracing.com/partde...6383&N=700+115, the lift is 420i/442e, I was doing the math and when I install the 1.6 rockers my lift will be 448i/472e. Does anyone know if this is to much lift for the springs that come with this kit or am I better off calling them. I cant imagine that would be to much. Thanks. James
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Since it doesn't say what springs are in the kit, it would be best to call them. Hopefully you'll get someone who knows what they're talking about.
Car: '89 IROC-Z
Engine: LSx
Re: To Much Lift For These Springs??
So I talked to summits tech line today, I said "I have a question about part # SUM-G5000". They said "ok". I asked "What is the maximum recommended valve lift with the valve springs the kit comes with?". I got a copy and pasted section from the parts page with lift specs on the cam? I just said thank you and that was that. So I will try calling Crane who made the cam for summit and try my luck. If no luck there I'm just going put the rockers on and see what happens.
Car: '89 IROC-Z
Engine: LSx
So I think I finally figured out what springs came with my kit, I looked at the came that I bought not in "kit" form and went to suggested parts and these are the only springs that were suggested http://store.summitracing.com/partde...+&autoview=sku I went to crane and the highest recommended valve lift is .487 so it looks like I will be all set
ZZ3Astro
08-13-2019 12:57 AM
TX-SleeperC5
09-24-2015 03:13 PM
