84 z28 5.0 HO 305
84 z28 5.0 HO 305
i have a 84 z28 5.0 HO 305 camaro. the only issue with it is that it wont start. it cranks over and pops here and ther but it refuses to start. i think that it isnt getting enough fuel and if thats the case how can i fix that. also what might the other problems be?
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: 84 z28 5.0 HO 305
Spill a little gas into the top of the carb, maybe 1/3 of a cup. Then see if it starts. If it does and then stops you'll know if it's the fuel. You can also take off the fuel line and hold the cup under the line and have a buddy turn the motor over while you watch to see if fuel is coming out.
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Any work done to it that would require the distributor to be removed? If so timing might be off if the distributor was not put back in correctly.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
A third of a cup of gasoline is WAAAAAYYYYY too much. A teaspoon would be more like it.
colton_carlson
03-08-2019 12:21 PM
