AC Delco plugs with headers?
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
I have an 88 GTA that will be getting some hedman headers very shortly. These are the headers I will be getting:
http://www.jegs.com/i/Hedman/500/68470/10002/-1
Anyway, I am getting them used locally. I hadn't heard from the guy for a while and need to get this car running, so I bought the stuff to reuse the factory manifolds, including the AC Delco R45TS plugs. The guy got back to me today to tell me when the headers should hopefully be ready to go.
I already installed the driver's side spark plugs and since they are new, I was wondering if it's possible to run them with those headers. Thanks for any advice you may have
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Re: AC Delco plugs with headers?
its possible, might melt your plugwires though. I used Accels special plugs made for headers.
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
I use the Delco R45TS plugs with Hedman 68481 /w AIR headers.
Cylinders 6 and 8 are ridiculously hard. Some guys modify spark
plug sockets to slide in and use a wrench to hank 'em out.
Wish I were that smart, I just unbolt the header and exchange gaskets
frequently and do the 6 and 8 plugs then. everything else is accessible.
But, yes.. you should be fine. I use Accel 8mm plug wires with angled
boots, just make sure you hang the access properly so nothing arks or
melts.
melts.
alrighty, sounds good
1992 Trans Am
05-10-2023 07:19 PM
evilstuie
02-28-2016 03:33 PM
sailtexas186548
01-19-2016 12:21 PM
