Banging Noise
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Banging Noise
My car is making a loud banging/grinding noise from underneath the car. It gets louder when the rpm's go up, and it goes away when I push the clutch in, and seems to go away when im coasting. What could this be?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If it only makes the noise when the car is moving, it could be a u-joint.
Sounds more like a bearing, though.
1 Post
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: Banging Noise
If it does it when the car is not moving, I would focus on the transmission. Any lube in it?
UltRoadWarrior9
04-28-2020 10:39 PM
sjorgens
10-01-2015 07:54 PM
