Valve to Piston Playdoh...What do you see?
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
This is the exhaust on #1. It is showing a lot of room for sure but something just didn't look right to me...like where the valve actually touched the playdoh maybe?
What do yo think?
What do yo think?
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Valve to Piston Playdoh...What do you see?
Mine did something like that. I guessed it to be that the stuff buldged over the valve and got pinched when the valve closed.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Playdoh isn't the best stuff to use, it's kind of springy and elastic. Modelling clay works better.
Since that's the last valve on the end it's an exhaust valve, which is smaller than the intake. Since the relifs are the same size on both sides of the piston (so they can be installed in any cylinder) you'll have tons of radial clearance around the exhaust valve like you are seeing there.
Try the intake valve on that same cylinder as well- raidal clearance will be a tighter on the intake.
Car: 1991 Z28
Engine: 383
Yea intake looks normal. Thanks guys, I am sitting pretty. Showing 0.268 intake clearance...and I thought I was gonna be tight with this .600" lift cam.
Car: 1984 camaro z28
Engine: L69 H.O
not to steal your thread but i see you are in louisville im in e-town dont see very many nice thirdgens around here just thought i would say hey.
Car: 1991 Z28
Engine: 383
Not a prob. Mine hasn't run (consistently) for a couple years but will hopefully be on the road in a week or so!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I also recommend modeling clay.
You went through all the trouble to install clay on the piston, torqued the head down, installed and adjusted rockers, rotated the crank to check piston to valve clearance and only did the exhaust??
Looks like you have lots of room. Those are very deep valve reliefs on a flat top piston. How many CC's are the reliefs?
Use a razor blade and slice through a section. It makes taking a measurement easier.
Car: 1991 Z28
Engine: 383
I agree on the modeling clay however the Playdoh was at hand and after seeing all this room I know I'm clear.
I only made one solid lifter so did one valve at a time. But, not thinking ahead I didn't realize I could have covered both reliefs with Playdoh and just switched the valvetrain over to the intake so I pulled the head again.
Didn't use a razor blade either, just a thin feeler gauge. The Playdoh being much softer didn't need anything very sturdy to cut through it cleanly.
From the paper work the original buyer gave me with the shortblock they are -5.4cc reliefs.
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
That number on the top of the pistons and the valve reliefs tell me those are the same flat tops I had last year. They are protrue forged wisecos for a 4.03 bore and 5.4cc valve reliefs.
355tpipickup
09-13-2015 11:35 PM
