brand new brakes dragging on my gta
Car: 91 formula
Engine: 350 tuned port. bolt ons
I have a same post in the brake board but no respones. I have an 89 gta new calipers new rotors and pads. the car stops very well now its just the car seems like the back brakes are dragging. slowing the car down alot. I do remember it was a very hard fit to but the caliper to rotor with the pads on. the car rims are burning hot to feel them with your hand. so what do you think i don't want to mess up my new brakes.
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: brand new brakes dragging on my gta
seized caliper? Bearings not adjusted properly? E-brake sticking. If you have drums in the back did you reset the adjusters before putting it all back together?
All wheels hot or just a few?
Car: 91 formula
Im talking about the rear brakes. new calipers so they should not be seized. thirdgens don't have wheel bearings in the back and its disc brakes not drums. both the back wheels are hot and smell like burning brake pads. I do notice If i slam on the brakes the car swings to right. so any idea of what is making my brakes drag on the rotor.
Car: 1987 Firebird
Engine: 355
Formula, if you have a seized caliper you will know instantly, because when you brake, the car will pull to one side.
How badly are they dragging? Can you still drive the car? What makes you think they are dragging? (not to be smart, but just curious, might be an allignment issue, and im curious to know how you determined they are dragging). If 1 caliper is dragging, and you are able to drive, after a drive, tat caliper will be VERY VERY hot, and the others wont be.
If you ARE able to drive it, take the brake components apart on that side, and grease all the sliders. Grease will work, but silicone lubricant works best. You will lube up the the two big bolts you pull off with allen keys,, and all inside the caliper where the bolts go. And the METAL contact points on the pads and caliper. Dont get any grease on the pad itself.
Hope that helps.
Hope that helps.
You only have drums in the back if you haven't converted....... Maybe one day
Anyway, I would jack the rear of the car up. Release the e-brake, then star spinning the rear wheels. I would assume that you would hear excessive rubbing or something. Were the drums hard to put back on?
Did you put the shoes on correctly? The shoes are specific to where they are installed. If you have the front and rear ones switched that may cause issues. I would take the whole thing apart one side at a time and redo the job. I know it's a pain, but better safe then sorry.
BTW there are bearings on the rear axles. They are just not adjustable.
Car: 91 formula
Hope that helps.
Hope that helps.
Terrell351
06-13-2021 02:13 PM
1992rs/ss
05-19-2020 08:02 PM
Street Lethal
04-30-2019 01:14 PM
1992rs/ss
16
01-28-2016 10:58 PM
