383 sbc gas milage
Car: 85 camaro z28
Transmission: auto to manaul
383 sbc gas milage
how much will my gas milage change from 305 to 383 sbc? its already pretty bad
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 383 sbc gas milage
Depends on what gears you've got, what cam you use, what induction system you have, how it's tuned, and how you drive it.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
All else being equal, it shouldn't be much different. The 5.0 TPI and 5.7 TPI ratings were basically the same, I think the 5.7 was like 1mpg lower city and hywy, 383 wouldn't be much different than the 5.7
Car: 86 TRANSAM
Engine: 406
Mine improved from 18 mpg with the 305 to 24 mph with a 406. Check you PM's for more data.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If you're getting poor mileage with the 305, you've got something wrong. Why would you want to build a 383 and keep what's wrong?
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
You may see an increase if the engine's output is increased in the area that you spend most of your rpm's. However a 350 tpi should have more than enough tq to get the car moving well at low rpms.
Mickeyruder
09-02-2015 02:45 PM
LT1Formula
08-20-2015 09:36 PM
