rocker arm compatibility
so i bought an 89 305 iroc motor from someone to find that it came with no rocker arms. it is a basically stock motor, i am not spending 200 on new rocker arms. before i go up to the junkyard, i am wondering if i can pull the rocker arms off of an LT1, 350, etc... the studs are 3/8". any ideas? if i can pull them off a couple different cars it gives me more options than searching down the one camaro in the yard and finding the rocker arms on it are nasty. thanks.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: rocker arm compatibility
I'd be surprised if a full set of new OEM rockers cost more than $50.
Engine: 383 Carb
Transmission: 4L60
I don't remember when the change-over year was... should be easy to figure out by looking at the heads though.
Engine: 383 Carb
Transmission: 4L60
No, factory self-aligning heads don't use guideplates, they just have narrower pushrod holes.
1 Post
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
GM sells a set of 16 will pivot ***** and nuts. Part #12495490 with a list price of $70.00, scoggin dickey sells them for $56.95 scoggin dickey
Summit Racing has them for $55.95 summitracing
EDIT: also check ebay: ebay
You want self aligning rockers.
92rsvortec350
19
10-09-2015 09:39 AM
