60cc heads on 305ci
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
60cc heads on 305ci
would the compression ratio drop too much on an lb9 with 60cc heads...i know they came with i think 58cc heads stock..i also have the stock pistons
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 60cc heads on 305ci
It won't be that much of a difference.
However the kicker is - what heads are these? aluminum? and have you verified the chamber size with a burette?
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
